dump valve location
gtirron
should the dump valve be moved closer to the turbo with a front mount?
I always thought the best place was as close to the inlet manifold as possible ?
Mines fitted in the standard valve position and i think this is the best place .
coxie
mine is fitted on to a custom piece of pipework near the throttle housing.the dump valve position is highlighted by the yellow ring 8)
Shaun
:D As close to the plenum as reasonably possible,to stop the pressure when the throttle is closed reaching the turbo and stalling the blades :!: Or so the theory goes :!:
