StateSideKendon
Well, I got the car about a week ago, had no problems when I drove it home (the car was warmed up).
Now on cold start it grinds into reverse (I didn't force it all the way in) and doesnt want to go into 1st-5th. I let the car warm up for ~3 minutes to see if it helped and no luck today.
Yesterday when I drove it it had problems for a minute or two, then cleared up, was a bit difficult to go in, then finally went in nice and easy.
Wondering if this is a gearbox BIG problem, if I should try changing fluids to synchromesh or a different highly recommended fluid or if it is possibly a clutch problem.
The reason I mention the clutch is that it's like the clutch isn't even depressed when I'm trying to get into gear. Although, once the car warms up and does go into gear, the clutch has no problems at all and will hold full load.
Any advice is appreciated, thanks.
--Kendon
--Kendon
