evidentally he fitted a manual pressure reg on car and its holding good pressure at boost which kind of rules out the pump and oe regulatorbad fpr or shagged fuel pump maybe
Thank you, :lol: your a great help, I'd be screwed without you for bits and help ......and advice, as I'm sure many others will agree!chris
fraid this is gonna be a last minute thing as theres a postage strike looming so im not posting anything out by royal mail.
i now have a spare ecu in stock plus a afm and also a lambda sensor, im guessing its one of the three and il edge towards it being an ecu fault.
if you like il bring the things to the trackday and you can try them there one at a time to see if that cures the fault or alternatively il send them via courier beforehand but youll have to pay the courier fees, then try the bits (one at a time) and if something cures the prob then just pay for that part and bring the other bits to give back to me on the trackday!
thats all i can suggest really
Your a saint bob!!chris
Hopefully I'll be getting the bits real soon from Bob to try, if anything goes wrong I'll let you know!:-D and if I get stuck and need help, I'll definately take you up on that offer!Your a saint bob!!
Chris, ive got a lambda sensor in the garage you can try, but guessing you'll need the other bits sending aswell from bob just in case its not that. Cant see it being lamba to be honest as it only uses that when in closed loop, full throttle you will be in open loop so the ecu shouldnt be taking any feedback from it. Let me know if you need a hand at the weekend at all.
Thankyou very much :-D Well I've got all my fingers and toes crossed so hopefully that will help too! :lol: As soon as it's sorted I'll be sure to let you knowparts are now en route chris, lets hope that one of them fix your problem for you
has anyone actually checked the base timing on this car?
sounds to me as though the engine timing could be out which will cause the car to struggle when coming on boost and it will obviously be lacking loads of power which it is
get a timing gun and set it to 20 degrees then make sure second mark from left on the pulley is aligned with pointer on pump cover, might be easier to mark the segment on crank pulley with a bit of tipex or similar!
my guess is it will be out;-)
Another one to try. Presumed it had already been looked at. Will that link with the fueling issue though?has anyone actually checked the base timing on this car?
In fairness it does feel like its got more than the 135bhp the graph gave!!! Kept staring at it and no faults jumped out. You might still get your moment of glory in finding it bob if its still running like that on tuesday.this is the first thing i said to chris with regard to the air leaks etc but hes adament that there is none!
get some washing up liquid and dilute it with a bit of water about 50/50 and spray it all around the inlet manifold and on underside (stay away from injector solenoids)
if it starts to idle really lumpy then chances are that he has a huge air leak around the throrttle bodies area.
wished i had been closer as i would have loved to have a look at this one, something there is very very wrong indeed. at the power thats making and the way car is running there must be a glaring fault staring at you lol
it wont be injectors aron as all 4 would need to be underfuelling and that is most unlikely, if an injector is faulty it will normally chuck a stream of fuel into the cylinder causing it to run very rich and the hydro carbon levels would go through the roof.
