Don't personally like the hks gaskets as the bore size is 88+mm which leaves a large lip around the top of the block (which has a aluminum deck) and the head (which is ali) and leaves you with an area of 1-2mm+ (on 86-87mm bores) that conduct's heat un-evenly and distorts and also promotes detonation via this un-eveness too... me,cambleju and other's have had this happen at high boost and power levels and it scrap's the engine after prolonged use, It's something i noticed some time ago Rob whether people want to listen or not is another thing. The cosworth gaskets need 0.5mm taking out of the dowel holes and fit perfectly they also come in different bore sizes (as well as thickness) depending on piston sizes you have selected .i.e 86 mm pistons you get a 86mm gasket ,87mm piston 87mm gasket and then you can select the thickness you require for the compression ratio you want and they are 1.2,1.5,1.8mm
