before you make a huge error sam (yes il help on this one so take my advice or leave it, upto you either way)
do not buy any of those headgaskets in links, the two links that you came up with are blueprint oe gaskets and way overpriced!
if you want a stock h/g which is all you need then go to a nissan dealer and buy one, it will not cost more than £30 for pulsar / sunny gtir.
if on the other hand you want to upgrade it then do not fit a cometic gasket link above) as it will blow, im not gonna go into whys and why nots but you will see!
only fit either a cosworth or hks h/g, the cosworth one will need the dowels opening out with a dremmel or drill bit but is around £90 and vvery good
hks is a straight fit but that will cost double that.
on the power your running you will only need a stock nissan gasket which is what was originally fitted, get head checked for flatness if it needs skimming then use a 1.5mm cosworth gasket
