No we didnt remove the bracket just unbolted it and pushed it towards the passenger side after removing the wiring connected to it and the dump valve pipe above at passenger side. This gave enough room to get at the det sensor with a few extension bars. Fitted new sensor then did reverse of above. We had a lift which probably made things a bit easier.hiya,
good to hear that so far so good when you say got it moved to the side, what do you mean? did you remove the Y bracket?
Cheers,
Lee
