has anyone had the det sensor play up and make the car run poo but not show up on a fault code check?where is the sensor on the block so i can try another one?
its right up the back of the engine underneath the inlet plenum. little black thing with a plug on and one wire going to it. problem is if you still have the y bracket on the back of the engine this has to come off to even get to see it
