datascan problem
williams
Need a bit help with datascan, can't seem to get it to connect to ecu. Wheb I open it up and click connect it saysinvalid port, so if I go into communications and change com port to 3 and search it takes about 2 minutes but eventually finds it. Once it had found ecu it still won't connect to it. Any ideas?
iomegalinux
maybe check in the device manager, the usb device is maybe in error (with à yellow "?" )
then also check if all the connection parameter are good in the windows device manager.
like port, speed etc...
williams
think i'll need to get my IT mate to do that haha
williams
got an activation code etc, it says it is now activated but i still only have 'data replay' and 'log analyser' available.
Trip
When the laptop is not connected to the ECU, It will only shows "Data Replay", "Log Analyser" and "NDS Activation" and the other buttons will be greyed out.
Is yours doing it when you are properly connected to the ECU ?
williams
ah right, not sure, i just activated it last night so havent had a chance to try it on the car yet. cheers
