Holey thread revival....
Just picked these gems of info from another thread, from someone with a lot more know how than me;
The cooling system for this car was designed when it was effectively a rally car, and as such forced to run with a 34mm turbo compressor inlet restrictor. As such, the compressor pressure ratio is extremely high, even for what would normally be fairly moderate boost, and that means your compressor is un-avoidably inefficient. This results in high compressor outlet temperatures and the requirement to reject quite large amounts of heat from the intercooling system.
Added to which, the main water radiator is heavy (it's full of water!) so mounting it low and the much lighter I/C rad high is sensible. By steeply angling the main water rad, the overall package height is also reduced and you can get some benefits from non forced convection cooling at low vehicle speeds (typical of UK stage rallying). As a radiator only requires something like 50-60% of it's core area as intake area (because the core itself reduces the flow area, and it uses highly turbulent flow to get good heat transfer) by tilting the main rad, and packaging the IC rad above it both rads get a nice cool air flow close to ambient temp (rather than have them sandwiched and the rear rad gets hot(ter) air)
The exit area is more than sufficient for both radiators, it's just a question of subjugation to avoid upheat at low speeds!
It's really noticeable with this cooling layout, that with the vehicle not moving, the cooling rad fans hardly even cut in at idle. In effect, there is enough convection driven cooling to remove the engines idle heat flux without cooling fans.
So, that's more info to dwell on for my pulsar rally car, also on 34mm restrictor...
Comments appreciated (its rare to get anyone to comment on the effect of compressor inlet restrictors)
Jon
