stumo
Yes you should plastiguage the ground crank and undersize bearings. If the clearance is too big then unless there is another (bigger) undersize bearing the crank is scrap.i do have one questions.. if i have clearances that are too large due to crank and bearing wear, then the crank is ground back and undersized bearings are used of the same undersizing as the grind, before fitting i should be using plastigauge to check the clearances.. what happens if they are not right?
if it's too tight (not likley) i can have a bit more ground but if it's a bit loose then i'm stuffed as the bearings don't get any thicker.
For the bigend bearings Nissan do 3 sizes of undersize bearings, 0.08, 0.12 and 0.25
For the mains there's only one undersize bearing, 0.25
There is only one std size of thrust bearings.
If the engineer is a good one then that should be the case but he might bot be..........or am i being a numpty and because they are new bearings and a properly ground and polished crank, it's all going to be super tight and bang on anyway?
