Crank Angle Sensor circuit
E
Evil_GtiR
I have ran self diag and it came up with 1 - 1 which means Crank Angle Sensor circuit. So now i know the problem is with the sensor, where is this sensor located and how much is it going to cost for the sensor?
E
Evil_GtiR
I think it may be very helpful if someone could post up pictures of engine bay with arrows pointing to all the sensors in the car. Will definitely make my life easier. Thanks whoever have the time to post one up! :D
j10gtr
I think this is the sensor located in the distributor. Well worht giving the connections a check clean the contacts etc. Then reset the fault codesw go out for a drive and check ecu again.
Thanks
Paul
paulrandy
Yeah the crank angle sensor is actually the cam angle sensor and is located within the distributor. should be some wires coming out under it about six inches long with a grey plug pn the end.
E
Evil_GtiR
Does the failure in cam angle sensor lead to failure in fuel pumps? I had my fourth new fuel pump in my car just over 1.3 years. Tats very abnormal?
