Ive just changed my rear discs and pads. All seem to go well, Slackened the handbrake cable, wound the pistons in using one of those piston block connector. replaced the discs and pads, put back on. Now the handbrake feels good, but sometimes the brake pedal goes to the floor (altho does actually brake when at full travel), seems to be after every 5 or 6 pumps, but then comes back up again to a solid braking feel.
Surely the master cylinder couldnt be knackered just from changing discs and pads could it? I left the resevoir tank cap off while winding the pistons back in so there was no build up of pressure, but now the cars probably a danger to drive and I cant see any leaks, the resevoir hasnt gone down at all.
Any clues? could it be air in the system, altho surely the feel of it would be the same all the time if there was air in the system.
Thanks
Sam
Thanks
Sam
