compression test
B
bean
Did a compression test on my car
Cylinder 1 - 155psi
Cylinder 2 - 135psi
Cylinder 3 - 155psi
Cylinder 4 - 155psi
But Dave and I did find a leaky injector on cylinder number 2 (fixed now) so it could of been running lean.
Cylinder 1 - 155psi
Cylinder 2 - 135psi
Cylinder 3 - 155psi
Cylinder 4 - 155psi
If it was leaking for a while, you could have had some petrol in your cylinder, washing the oil off the bore on start up, accelerating wear and leading to the lower compression on that cylinder.
B
blr123
So it looks like 8bar (118psi) is low :roll: what I didn't mention is that the car has Forged pistons but the head gasket is standard, does this make any difference :?:
Also, the young lad's car is a bit noisy cause the shimms need setting up "Big Job" :?:
Cheers Bryan
It would if they were low compression pistons, but I'm not sure how much.
B
blr123
Thanks Fast Guy,
They were supplied by Norris Designs if that makes any difference, I'm thinking that they possibly supply specific types ie low compresion :?:
Cheers Bryan
