clutch wont budge
yesterday my clutch started to play up, was tough to select 1st when stationary, and wasnt quite normal changnig through the gears once moving, i took it easy, then dropped it into the mechanics this morning, they changed the gearbox oil, bleed the clutch and adjusted it, when i picked the car up it was fine, but after 50kms and luckily right as i was about to pull into my driveway, it just gave way, wouldnt select, i pumped it, only to find it harder and harder, now it wont move at all, and it was making some kind of grinding noise when outta gear until i turned the car off :shock:
any ideas? looks as tho im going to have to get it towed bak to the mechanics in the morning :(
