clutch slip on launch...
andygtir
when i launched the car the other night the clutch slipped totally, barely got off the line, and then continued to slip through into 5th. since then taken it easy and not done any fast changes and havnt noticed any slip when in gear and on boost.
it used to survive these launches with ease, but i guess after a year of complete abuse its finally had enough. :roll:
generally do the clutches progressively get worse until the point when it starts slipping when on full boost or will it just suddenly give up the ghost and leave me stranded :?:
jasegould
Clutches will progressively get worse, I drove round for a month on mine when it first started to slip.
They can fail totally and leave you stranded but that not usually due to worn clutch, usually bearing failure or broken internals
