Hi,
I get this rattly/whiny noise which is present at idle but when you press the clutch down it disappears. The rattly noise gets slightly quieter as the car warms up. I also get a rattly noise as I drive off at low revs. As the car goes above 2000 revs the noise stops. This only happens in the first and second gears.
I have done a search on this and the Input Shaft Bearing seems to be the culprit, however 2 mechanics have told me it is the Thrust Release Bearing :?
I have a few questions...
1. Which bearing is it?
2. Does a Thrust Release Bearing come with a new Clutch Kit?
3. How much is each bearing and has anyone got the part numbers?
4. Will the rattle at idle be a different cause to the rattle when accelrating
at low revs
5. What happens if I leave it too long?
In any case I have decided to replace my clutch with a Helix Organic.
Thanks for your help and I apologise for the lengthy post.
Hope to hear from you soon
at low revs
