clutch problem
JIMMYBACK
right finally i got my mates pulsar back on the road...............before mine i know but his is in a more a road worthy condition:doh: :shock: anyhow the only problem left is the clutch after about 10-15 mins the biting point drops n drops till you can select gears:shock: :shock: :shock: ?
you leave it for about half hour and it back to normal?
ive checked the normal master cylinder leak inside the car by the pedals and nothing is there.clutch hose appears to be fine too wtf is going on any ideas people:p
paz
Probably worth bleeding the clutch fluid fella, had a similar problem on another car and that fixed it :)
paz
Rishi
Still waiting on some shims!
Pedal Box on its way off... Air in the system... Check those out first..
Rishi
stevepudney
GTiROC CHAIRMAN
I bet it's nakerd old clutch fluid that shows less and less resistance as it gets hotter, allowed to cool for a while and it works again.
I would bleed the old fluid and replace with some DOT 5 synthetic fluid.
Steve
