		J-GTi-R
This is for a mate who doesn't get on here very often.
He recently had an AP organic clutch fitted to his car (far too heavy for my tastes, but there you go) and while it was fine for a while he started getting problems changing gear, like the hydraulic system was losing pressure. I checked his car and there are no signs of leaks anywhere, both the master and slave cylinders seem fine and the flexi hose is dry. However, taking the cap off to the cltch fluid reservoir I immediately spotted the fluid was almost black and very cloudy. We bled the system after flushing new fluid though it and it was fine for a couple of days. However, the clutch started dragging again and the new fluid turned black almost straight away. He's had another mate look at it, who has tested the flexi hose for expansion, but he couldn't spot anything. His mate also flushed the system again, but now reports the biting point is as soon as the clutch pedal comes off the carpet, which wasn't the case before.
Anyone got any other ideas, as we're a bit stuck and are getting sick of being told the clutch fork is bent (which we both think is very unlikely)?
