nitrosgti-r
anyone got any pics of a standard R clutch please?
Look for numbers on the friction plate and also take a pic of the other side of the pressure plate to determin if it is a helix on first look it does look like one but need to see other side to be sure ;-)nitrosgti-r said:fook, i thinks its standard then. Grrrr. i bought that off someone from here
>>>>>>>>>>>>>>>> stevo_123uk <<<<<<<<<<<<<<<<<<<<<<<<<
And he said it was a helix organic clutch, all balanced in with a knife edge crank and lightened flywheel. HUH !!!!
see here......
Well i dont know if the nismo spec cover would have been any better but the HKS one i have looks very similar also but has heavier springs so would hold better due to greater pressure on a standard disc its possible the nismo was the same idea not much point paying like £500 for one then to find its the same as a £270 kit out off AP racingShaun said:If it is a Nismo clutch then i believe they are stock replacement and wont hold any more torque.
well, at least the crank looks like it's knife edged :-Dnitrosgti-r said:fook, i thinks its standard then. Grrrr. i bought that off someone from here
see here......
So is the first thread pic a Nismo one Bobby? ohh do you know the clamping force?pulsarboby said:Thats A Nismo Clutch, I Have One Sitting In Workshop!
