Clutch Pedal problems - AGAIN!....steups......
B
beast14
guys, this thing is very frustrating...........initial problem - the clutch pedal started getting weak then it finally stuck to the floor, wouldn't come back up, lost pressure...........here what i've done soo far - i've changed the clutch/brake line , i've also intalled new kits for the slave and master cylinder i.e the seals have been changed................even the bleed nipple............the pedal would work for a while and then i'd have the same problem............and when i bleed it i'd have pressure again each time.............also, sometimes the pedal squeaks real loud - this sound appears to be coming from the engine bay - i've been told that it might be the fork....is this true??....and is this related to my clutch pedal problems???.....................what else can i do???
kyepan
i know this sounds silly,but try puttin a dab of copperslip on the clutch fork pivot, as that solved a really juddery super creaky and spongey pedal..
why its going to the floor though i would not know.
