clutch noise
R
r5ben
ive just fitted a new clutch to my R and it works fine and has been in for about 1000 miles the prob is that when the car is at a stand still and running at idel the clutch makes a noise but if you put the clutch pedel in and hold it down the noise goes away etc etc ?? :? i had everythin new when i did it ie new bearings ,ap paddel clutch and did the fidenza flywheel at the same time so what could it be ?? it works fine and its not sliping :oops:
does it want bleeding or something simple like that ?/ or is that how its going to sound ?? :roll:
daz
could be the input shaft bearings in the gearbox as i have found out to my dismay myself that they are very much suspect. and the reason that it stops when you press the clutch is that the box then stops spinning so it does not rattle
R
r5ben
well ive had the clutch release bearing when i did the clutch and im never made the noise b4 i did the clutch just starting to now ??? :cry:
mattygti-r
thats the noise of hte AP paddle clutch , nothign wrong with that
its a slight "rattle?"
mine was like that
OH
until it decided to rip my car to bits :roll: :roll: :cry:
Ben youve PM mate please reply
