B
beast14
i've got the ACT 6-pock solid clutch and the Xtreme P/Plate.....it works fine!!!!..........
my problem is that because of the extreme pressure i have to change my clutch master and slave kits often because the seals can't handle it........
so, quite often my clutch pedal is stuck to the ground because air keeps getting into the system........
anyone has this same problem?........if not, any suggestions???
could i source a clutch master and slave from another nissan vehicle that is heavier for eg. pick-up, mini bus..........
help needed urgently........it's very frustrating!
