E
Edd
Right i have an OS Giken twin plate clutch in the car with a quaiffe box.
Ever since it had beeded in i have had a judder through the pedal when the clutch joins and also it does it if you change gear and let the revs drop.
It also does the chewbacca noise when you pull away at times and also sometimes on gear changes (os giken owners know what i mean :lol: )
However the judder seems to shake the front end to pieces :shock: :lol:
and i'm worried that under hard launching i might blow something up :shock: :?
The judder got worse and worse recently and then funnily enough i discovered one of my tyre pressues on the front down at 20psi :evil: :?
so i put them up to 34psi and there is hardly and juddder at all :shock: :lol:
yet again though the judder was getting worse again, so checked tyres last
night and they were down to 30psi..........abck up 34psi and its fine, i can let the clutch out in first gear on tarmac with no revs and it judders ever so slighty (hardly anything) and the car doesnt stall either.
So do i have a problem somewhere or are tyre pressures that critical :shock:
also to note on my MOT we noticed that my drivers side top mount is causing a slight knock on steering so wondered if that might be causing a problem.
I have all new CV joints and wheel bearings to go on the car soon so hopign that'll tighten it all up a bit.
