antgtir
I broke down on Friday . The withdrawel lever which sits onto the clutch release bearing has come away and flopped around causing the piston which pushes the lever to pop out and fluid to leak out (pedal to the floor job) so while the box is gonna be coming off, i thought seen as my clutch has been juddering like feck 20k after i bought it, id get another and poss a new flywheel.
What i need from you guys with the knowledge and experience is which make to go for? for both the clutch and flywheel (lightened and balanced etc or just standard)
The car is totally standard apart from a goose exhaust, and is running standard boost. If any of you can help id be very gratefull, cheers,
Ant.
Ant.
