Decided to change the clutch fluid today, bled out lots of black crappy fluid which had little bits of black crap in too. Now there is no pressure at all in the clutch pedal, press it down and it stays down. Theres no resistance behind the pedal what so ever. I stripped down the slave cylinder to check all the seal and they all look fine and no leaks round that area. No leaks around the clutch pedal either, all I can think of is that the master cylinder has degraded inside so theres no seal left. Weird thing is, it was fine before I bled it, so why would it suddenly 'go' ?
