Stoned
As per the instructions in the post 'HELP!!! - Won't change gear at high rpm...' I went out to adjust the clutch bite point on my car since it's always been too low and I often get problems selecting gears
I got right under the pedals (very rushy with your feet in the air and your head in the footwell! ) and found to my confusion where there should be 2 nuts there is only 1...
The nut I have removes the lock so you could then turn the shaft, but where is the second nut that allows you to adjust the screw length itself?
I took some photo's so you can see what I mean and hopefully tell me where I am going wrong
As you can see, only one nut visable
From right underneath. As you can see, I can losen that nut, but then how do you actually turn that screw :?
Any ideas?
Any ideas?
