Changing the clutch bearing
Is it easy to change the clutch bearing, or is is till the same amount of labour as chnaging the whole clutch?
Its just I have a feeling my clutch my outlive the bearing, and I have heard it can do quite a bit of damage when it goes
cheers
Dan
ex-gtir
yes its as much work as doing a clutch mind you it may be your gearbox as mine sounded like the release bearing turned out to be 1st gear had lost a tooth i have send you PM :wink:
mike
purplemonster
well i made the mistake of buying a bearing and then buying a kit ,so i know have a spare genuine nissan bearing ? doh!
ROB
