No worries, I understood what you meant matey and wasn't trying to be funny. Just post up my thoughts on it !Cambridge_pulsar said:I do agree with what you're saying, it sounds like a fuelling issue. I have an uprated fuel pump and have re-wired it direct to the battery. I was just using the injectors as an example, if one component is struggling on standard boost I would expect the problem to be worse on a higher boost setting.!
I'm in sunny Milton Keynes mate. Last time I checked, it was only around 40 miles drive ?!Cambridge_pulsar said:Swapping the ecu's hasn't changed anything, although i'd say it runs a bit better with the mines unit. Where abouts are you, I may take you up on that offer!
Have you checked the fuel pressure ? Both static and with throttle ?
Paul
