Cambridge_pulsar said:
Ok i'll try setting it with a multi meter tomorrow.
I have swapped the maf a while back with my mates old one that was happily running about 315bhp. I have since cleaned the contacts on the plug, re-earthed it and opened it up and cleaned the sensors so i'm happy that's not the problem.
The thing that confuses me is that the symptoms are the same on standard boost, if say the injectors were maxing out at peak revs on the 1.1 setting you would expect the symptoms to be lesser or non existant on standard boost.
Btw I have changed the ecu (for a mines unit), dizzy, cap, rotor arm, cleaned various earths and probably a fair few other things. Your help is appreciated.
It definitely sounds like a fuelling issue.
Is the ecu on the car now, the Mines unit ? If so, could you change back to the stock unit as a few people have mentioned rough running with Mines ecu's recently !
Do you have a high flow fuel pump ? If you do, is it on the same loom as the stock one ? Or has it been rewired to get full alternator voltage ?
Your injectors won't be maxxed out at 1.1 bar..... When I say that, I mean that they maybe at 100% duty because the ecu has gone off the fuelling load map but, they'll be supplying enough fuel for the engines needs.
That's my take on it anyway and I'm sure some will disagree !
My car was putting out 318 bhp when it was last dynoed at 1.1 bar (and supposedly running lean although, it was on the original, 95k miles old stock fuel pump).
With everything 100% now, it runs a dream. That's with basic mods and still running the stock TMIC.
I had a niggling problem like yours so, know how it feels !
I'm not that far from you, if you're still in Cambridge so, if you run out of ideas, please feel free to come over and I'll plug the DataScan into it and see if anything comes up !
Paul
I'm sure you
