mattygti-r
dont know if anyone on here uses them but you know you can use the RX-7 brakes as a swap for bigger brakes on the GTI-R i believe
who' s doing your hoses mate??J44MAA said:Same as above
If you want i can tell you exactly what fittings you need and how long the brakeline needs to be. If you give that info to pirtek they should be able to make you up a set (unless they're complete nobbers!!)J44MAA said:A place in Glasgow called Pirtek are gonna try make them up for me. I need a set of old brake lines first tho so I can take them down with the Evo caliper.
