Big brake rotor hats/bells
PiNiOn
Does anybody know where i can find a pair of rotor-bells made for the GtiR? I wanna purchase a pair of Willwood calipers with 1.25" rotors, but i dont know where to find the hats/bells to fit the Wilwood rotors (8-bolt)..
PiNiOn
Its 1.25" disk width!:-D Wilwood can suplly me with universal bells for the offset i want (that means i ll need to get them drilled), for 100GBP each :shock: .
If a caliper is made for a 1.25"(31.8mm) disk width, can it also be used for 30mm or not? There are many disks choices for 30mm width..!
I would imagine it would be just like having a slightly worn pad or disc, the caliper pistons would need to be slightly further out to make contact between the pad and disc.
