ok also i must have a fuel pressure of 3 bar and that´s ok? What you mean with (660cc injectors flow 858cc's of fuel a minute @ 5bar of fuel pressure)? Is this not the same with the 660cc flow 660cc??? Where is the different?Sirnixalot said:you shouldnt need to run 5bar of fuel pressure. THe most base fuel pressure you want is 4bar.
If you need to run the 660cc injectors @ 5bar to supply the engine with the right amount of fuel you need larger injectors.
660cc injectors flow 660cc's of fuel a minute @ 3bar of fuel pressure.
660cc injectors flow 858cc's of fuel a minute @ 5bar of fuel pressure.
You will over heat the injectors and possibly cause the valve they use to stick because it cannot close with that kind of pressure on them.
Get some 850cc injectors and bump the fuel pressure down to 3bar.
Also i dont know anything about kent camshafts...do you have the specs?
I want amnyone who has fitted the Kent Camshafts in the R. So told me Need for Speed that i can fit the 284°/271° camshafts without other valve springs...
What you think???
