I know how awful the standard brakes/discs are.
I am looking to get performance discs. I would preferably like to get bigger discs. Can this be done without buying a big disc kit set,i mean is their any suppliers with discs that will go straight on with standard caliphers etc. Slightly bigger then the original size.
another question would be what is best,drilled,grooved,or drilled and grooved.
As i thought it would be best to go for drilled and grooved,but have been told that i will find that they will crack if drilled,will find hair lines through them,how true is that?
The reason why i want to go for performance discs that go on as standard as i dont want to restrict myself in wheel sizes. as with the big disc kits,you will usually find you have to run 16s!
Can anyone reccomend a real good front performance discs whether same as standard size or slightly bigger?
I am running 280bhp,now bearing that in mind would you think il have to go for a big disc kit?
or could i get away with some performance discs,drilled,grooved etc
has any one tried god speeds extreme discs £225
