Yeah its no guarantee:lol:
I have seen that thread before, but having thrown rockers in the past without ras and it making a pretty big mess, i though what harm can ras do:lol:
To be fair the pistons only just kissed the valves on a couple of cylinders but still enough to bend the valves,the bottom end survived though.
It ended up with i think 5 thrown rockers,some broke, a chunk out of the cam and a stretched chain,which i am not sure if it was the cause or happened during.
Maybe with ras it would of damaged the pistons worse with the valve contact mostly on one cylinder,but tbh if a rocker breaks free under there you are in trouble either way imo.
Also reading that thread and not really understanding valve float gets me confused
:lol:
What is he saying there,that the main cause for a rocker coming free is due to valve float from an over rev?
Where i dont really understand valve float i cant really comment,but is the sole reason for rockers coming free/breaking,and the sides of castle guides snapping off etc all due to valve float?
Do the gtir stock springs suffer from this?do you get valve float when bounching the limiter?
Then i sort of read it as if you do then fit new springs and retainers and cure valve float that ras are a good idea?
I am not sure tbh,i know the poster is very knowledgeable/respected but on my past experiances i am going to stick with the ras,if it makes a worse mess than last time i will be impressed:lol::doh:
I need to understand this valve float a little better tbh.
