PaulB said:
I dont agree with you there, its purely based on the volume of air, and the area of the 90mm Q45 MAF is far bigger than that of an 80mm Z32MAF, and therefore flows more air as a result.
the nissan mafs are hotwire types, the wire is heated with an electric current, as the temp increases so does its resistance, in turn reducing the current flowing through the circuit, as air enters the intake and flows past the wire its is cooled, reducing its resistance allowing more current to flow which again increases its temperature and resistance until it reaches the point where the resistance is no longer increasing. The amount of current required to maintain resistance is in a direct relationship with the mass of air (not volume) flowing past the wire.
if the density of the air increases, due to changes in pressure or temperature the heat will be removed from the wire quicker which would appear to the maf circuit to be a higher mass of air.
the ciruit of the maf changes the current into a voltage which is what the ecu see's
The z32 maf, being off a turbo charged vehicle probably takes all of this into account with its calibration which is why the size difference in the q45 doesn't make much difference in its ability to measure a higher mass of air entering the engine..
possibly, maybe...i think...more to the point, maf sensors are for losers and you should all be looking at map sensors anyways these days, its is the year 2007 :lol: there is a standalone unit available now that will allow a map sensor to be used on an engine/ecu set up that normally uses a maf 8)
