The pressure in the hydraulic system changes quite a lot in my car....
sometime u can push the clutch in and it's no problem 0 same as usual
other times u have to push the clutch pedal practically to the floor before u can change gear.....it springs back up ok..
I found out that when the clutch has to goto the floor to change gear, I can gently pump it without it affecting the engine and the pressure builds up for u to change gear normally again....
I have completly bled the system and it made no difference (was there b4 i did this).....what could it be?
