Ajusting clutch pedal slack
Stoned
Something else bothering me is my clutch pedal has quite a bit of play in it up and down before you actually start to move liquid around the system. Can this be adjusted at all?
Otherwise it works fine.
yes there is an adjuster that screws down onto the peddle arm, you will have to get upside down with head in the footwell to see it, may want to bleed/change the clutch fluid whilst you are at it as well.
