The GM type MAP which is used in my aftermarket ECU's such as AEM, Motec, Haltech, Apexi ect all use a GM rebranded sensor and need a 5V feed. I am talking about the 1 to 3 bar MAP sensor, not sure if the big brother 5bar sensor works the same.Sure it needs 5v? A lot use 12v.
If you are despirate for a 5v feed you could dismantle a car USB charger and permanently wire in as they are 5v.
that sound like a real junkie. I was hoping to get away wiring up a voltage regulator (LM78M05) and heat sinking it.
Yes - TPS is 5V isn't it?Does the MAF and TPS have a 5v supply ?
My competance streches very wide, from being a porn star(Straight) to a Atomic Physicistthats the correct way to do it but didn't know your level of competance
