4x100 will fit, the et38 should be ok, but don't quote me 100%. 6.5j is the width of the wheel and that should be ok, although a little on the thin side 195 tyres would fit rather than 205.4x100 et38 6.5j
does this size fit the gtir?
That's generally the deciding factor; it's quite large as centre bores go, so if the wheels were designed for a Golf (as an example) they won't fit. - Generally the after-market wheels have a large bore and spigot rings to bring them back to the required size.Whats the centre bore? You need 59.1 mm or bigger
Yes that's important too, good shout!Whats the centre bore? You need 59.1 mm or bigger
