gt2871r, cant try it yet my coil is fooked waiting for my new one to arrivestevepudney said:What turbo you got ??? does it sound any different and what does it go like???
stevepudney said:It was tried and tested, Bruce (Pimp) has had a complete system on his car for months now with no problems. Trouble is it was fitted by Janspeed (who made the system) with all the necessary, tools, ramps, Lambda adapters e.t.c. on the shelf.
As for the bolt holes in the flange they do appear to be tight when put up to the turbo although with a little encouragement (rubber hammer) will fit.
Anyway, Gary what happened to that complete all Titanium system for £20 or something daft.
The stud pattern on the 2871 (and alike) is different from the standard turbo's so some filing would have been required even if you tried fitting the standard dump pipe to itnismoboy said:Ive enlarged all the holes and ive fitted it to the car looks good but what alot of hassle
Yeah my jgy turbo has a slightly dif stud patten so i had to open one of the hole's up a bit.GINGA said:The stud pattern on the 2871 (and alike) is different from the standard turbo's so some filing would have been required even if you tried fitting the standard dump pipe to it
Crazy said:Lads where did you guys getthe part that enables me to fit my standard lambda as the hole on my Janspeed front pipe is way too big and when I went to B&Q for an adapter they just looked at me funny and said that they did not have any :roll:
