272 cams
Empty Pockets
Nope, but i'd put uprated valve springs with those, iirc the hks 264's are the only cams that are a drop in fitment, i.e no need for uprated springs and retainers as the lift and duration isn't too much.
Empty Pockets
Probably mate, unless you can find someone thats hoarding a set lol. If you're buying springs then you may aswell get pulleys, you'll be able to dial them in perfectly then.
turugtir
With adjustable pulleys you can gt very good results if you know what are you doing, especially in the mid range, that is where the turbo starts to make boost, thus reducing turbo lag. You don't have to use them, but if you do it set them up well you can get very good results.
The only problem is that to do it well you have to know about it, or leave it to somebody that knows what he is doing. In this engine is even worse because you have to undo the rocker cover to make adjustments, so it makes it harder to set up because the camshafts are chain driven, so you would have to think if is worth the hassle.
shroom
see if you can get a cheaper price if you email erics performance and ask if he does the vernier cam pullies too as he might do a better dea lthan what is listed, every little helps, might aswell go full out on this beut ;) .
or dont get the cams, and keep stock head, get your 400bhp and have some change left over for a spare box or some other part, but then who wants to skimp that lumpy idle will be :love:
