G20_GTI-R said:
See not bad effort :lol:
Right 1st thing to make sure is the two lines on the "Valve" are correct way round and on correct ports on my apexi it has "no" and "com" on it which go vacuum chamber and to actuator respectively
Then make sure the feed going to the new pressure sensor is good and of course all lines are secure.
The hard part will be setting up your base boost map but your basic settings will be first finding the actual boost pressure and then setting the duty (% time open) at a given rpm to set the required boost level. Easy to understand really as a boost level of 1.5Bar with about 40% duty is a good starting point.
Someone with more experience on your controller will be able to simplify things for you but I know on the apexi we have a learning mode when the controller actually monitors the boost levels so it understands what range the car runs so it is not trying to go between 0.5 Bar and 2Bar which would make for an interesting ride
:lol:
