S-GTI-R
like an uprated lamba sensor or sumthin?does it jus screw it2 the same place and replace the lamba?
yeah but with this you can leave it on http://www.innovatemotorsports.com/products/xd1.phpKRS said:You dont attach it to the car![]()
Its a device used in tuning to make sure the air/fuel mix is correct, then you remove it.
No, they are designed for constant use, a lot of newer cars come with widebands fitted as standard.KRS said:8) I thought they burned out pretty quick under constant use though?
your head gasket finally lets go???Fast Guy said:Will you people be quiet. You nearly talking me into seeing how far I can turn the boost up before :?:
