hello mate, you live just up the road form me ...live in braintree...finally another R in the area i though i was going to be the only 1 round here with a R ...hopefully you'll get the R back on the road soon..Let me know if you want to meet up...leon2engines said:im in witham mate,
Go on you know you want to :lol:..you'll want more power anyway :twisted: then more booost, :lol:RishiGTiR said:leon2engines said:oh dear, i attacked my new toy with my trusty spanners and discovered ive got a slightly melted piston! :shock: but lickily no damage to the bore what so ever, how lucky! will i get away with replacing just the 1 piston with a standard one?
Melted piston could be from DET... This could have damaged the bore...
You must find the cause of the melted piston or you'll just do it again...
If you are going to replace the pistons why not use Forged Pistons... They are only £300 for a Forged Piston, Ring, Clip and Pin set...
But then if you go that far then you may aswell change to ARP Bolts and new bearings too... Maybe some Billet Rods aswel...
Rishi
leon2engines said:where can i get them for £300? are they a strait swap? ive been quoted £200 for a set of standard ones!!
YHPMleon2engines said:!!!DEFINATLY!!!
what the hell is F.O.D?? is there and areas in perticular the heads crack? the bores are fine thank funk,carpy100 said:have you checked your head for hair line cracks and your valves and seats. also around the top of your bores det tends to eat away and damage these areas. also check your turbo for damage cos its probably had some f.o.d put through it. .
