will 15" alloys fit over hi spec 285mm big disc kit?
scottyd
hi, just wondering if anyone knows for sure if 15" alloys will fit over hi spec 285mm big disc kit?
thanks,
Scott
Fazz
Well I have the Wilwood with 285mm discs and the 15"'s fitted grand...
Should be fine lad.
:? i was wondering same thing as i was told they wont fit anything under 16s:-o
Fazz
Checked there - mine are 280mm discs and fit fine over 15" Tsw's..
Possibly the Hi Spec's are a thicker Caliper which causes teh problem?
Not sure if others here can help as most with uprated braes are running on 16/17s anyway..
I'm sure they know what they talking about so you may need to upgrade wheels or change calipers.
Here's the Kit I got anyway.. Cheap considering and the braking is spot on.
Lose the ABS too... :)
http://www.rallydesign.co.uk/catalog/product_info.php?cPath=562_563_568&products_id=3957
