which walbro fuel pump for a gti-r??
str_motorsport
hi, i was looking on ebay for a walbro 255l\h high pressure fuel pump...i don't see a specific kit for the gti-r...so which one will fit the gti-r?which pump are you using on your r???
thanks
donpulsar
South Yorkshire Regional Rep
Walbro GSS341. Ignore the numbers after the 341. Make sure it's the high pressure, 255 litres per hour version tho :)
str_motorsport
and the fitting kit?does all pumps come with the big black rubber that should be fitted over the pump?
donpulsar
If you buy the kit from Hiteq you get the cover. Not sure about anyone else tho'. Or just go to your local pipe / hose shop and ask for some fuel proof hose. :)
