Which rods and crank??
B
Brett G
I may need a new crank shaft and rods so which ones should I go for that are a reasonable price? and where's the best place to get them from?
Any help will be greatly appriciated :wink:
JU5TY
I would stick with the stock crank unless your going for a stroker kit. The stock crank is very strong.
As for rods, they dont need changing usless your going for big BHP? There are a few different makes on the market. I would change the con rod bolts to ARP ones though while your bottom ends out... :D
B
Brett G
The big end bearings failing could've damaged my rods too thats why I ask,do you think that I should just go for standard stuff?
JU5TY
Yeah there’s no need to upgrade the Crank and rods are only necessary if going for big bhp, also I don’t think there’s such a thing as a reasonable price… :wink:
If anything I would change the con rod bolts to ARP ones. :D
B
Brett G
Cheers Geeza!! :D I suppose if I wanted a reasonable price I should've went for the micra instead! :wink:
