which fuel pump
s18rra
well i want to buy a upgraded fuel pump and see that most of you use walbro, now is this the best one to use as a few people have told me that there not all that and to go for a bosch.
which bosch model number would it be and how easy is it to fit compared to the walbro.
also more importantly how do i check if i have one already, i dont know much about engines so please keep it simple.:oops:
R
riske
Pull out the old fuel pump and see what the label says on the side...
s18rra
im gonna sound like a plank but where is it and how do i pull it out
gtir_pimp
to keep it simple for you mate, get a mechanic to check what pump you have as you say your not very good with engines then dont take chances especially with petrol! And walboro pump is good and will only cost about £40 to change. you should be able to hear a loud priming noise when you turn the ignition and all the lights come on the dash just before you start the engine
R
riske
and Usain blot would of already ran the 100m and 200m backwards before Johnston got to the changing room.
