Walbro Fuel Pump?
nickg123
Just got it (at last)
How easy is it to fit?? I don't even know where to start..........
Is it under the rear bench?
ashills
its under the boot carpet on passenger side
take fuel pump fuse out turn car over to take pressure away
take off the covering plates
then take the cover off the top of the tank twist i think
the pump is then in a carrier on the bottom of the tank u have to un clip the strap around the pump or take the whole lot out then connect the new wires and put the bits of pipe in the right place then check that the pick up/filter is gonna get a good flow of petrol (ie not facing upwards)
put it all back together then check for leaks etc with the car at idle then take it for a short drive to check its all ok
dont where latex gloves like i did as they blow up like ballons and break up in ur tank LOL
GTIR-LOZ
also dont cut your hands as petrol really really stings :wink:
you will have to cut the plug and wires of your old unit and solder them onto the new one, and the fuel pipes at the top of the tank, and a bastrd to get off, as they have prob been on there for 13 yrs or so :(
jasegould
Yeah, dont muller the fuel pipes getting them off like a friend of mine did :oops: as they only just reach and you'll have to replace the whole lot which is a pain in the arse
nickg123
Hmmmm.......... really not looking forward to doing this one!!!
Anyone fancy doing it lol!
May have to tap up Mike for a quote..............
purplemonster
give it a go mate .they aint that bad to do at all
ROB
There's always GINGAs How to guide.........
Right then as promised[]
At this point I must add that this is for the uprated fuel pump supplied by Hiteq so may be different from other makes[]
The new pump kit
Tools you will need are
10mm socket
exstension bar
Ratchet
philips and flat bladed screw drivers
wire strippers and crimpers
2 straight electrical contectors
Make sure you've got as little fuel as possible in the tank before you start you see why later[]
First off disconnect the battery[]
Loosen or remove the fuel cap
Next remove the boot carpet on the lefthand side of the boot you will see a large metal plate held down with 5 10mm bolts and a wiring harness going into it,see below
With the cover plate removed you will see a large cover/cap on top of the fuel tank with 3 pipes going into it and two wiring connectors
,remove the large breather hose that is above it and place out of the way,remove the two wiring connectors from the cap and disconnect the third one that goes down the side of the tank you can then position the metal cover and loom out of the way,remeber/mark which pipes go where then loosen the fuel pipe clips and remove the pipes from the cap but beware these pipes are very tight(stuck) on the connectors and will be a pain to remove also there maybe some fuel pressure in the pipe on the left still so be prepared for some spillage[]then remove the large plastic lock nut that holds the cover/cap down by turning it anticlockwise I found it best to knock it round with a large screw driver.
Know clean off as much dirt as you can from the cap etc to avoid anything dropping into the tank[]then lift the cap off(make sure rubber sealing ring doesn't fall in tank[], attached to this you will find two hoses and two electrical connectors,disconnect the 2 pipes from the cap remembering which goes where[]and disconnect the 2 wire plug that goes down to the fuel pump and place the cap out of the way and can also disconnect the other wiring from the cap that goes down to the fuel level sender if you like,you can know see down in the tank and realise that everything anybodys told you about changing the fuel pump is a lye and its not going to be as easy as everybody makes out[V]
If you look down through the hole towards the front of the tank you will see the fuel pump retained in its holder attached to the base of the tank and wonder how the hell you get that out[]it was at this point I forgot to take pictures so sorry about that[:I]what you can see in the picture above is the mounting for the fuel pump carrier[]
Now to remove the fuel pump I removed the top section of the carrier by wiggling it and pushing it backward(IIRR)either way it will only come off one way,then I just lifted the pump out of the carrier and out of the tank,make sure you retrieve the 2 rubber ends that position the pump in the carrier,the lower part of the carrier can know be slide out of its mounting(towards the back) and removed from the tank,also on mine it had a antisurge tray attached to the back of the fuel pump which prevented me removing the pump and carrier in one go as it caught on the mounting bracket,this tray didn't look like a standard fitment[?]so might not be yours,if it is remove it from the tank aswell.
The old Fuel pump
Now attach the new fuelpump pick up supplied in the kit to the new pump and secure with the retaining washer/clip supplied.
Now with everything removed you can fit the new pump into the carrier using the rubber ends from the old pump,the new pump is a bit slimmer than the old one but is supplied with a foamy overcoat thing to slide over the pump to increase the width,then put the rubber end covers over the ends of the pump and fit into the carrier,the rubber ends are moulded to fit into the carrier so can't really be put round the wrong way[]then refit the carrier top section to hold the pump in place,I then just slipped the antisurge tray between the fuel pickup and the carrier so you should end up with something like this.
Now comes the bit where you start to worry[]
cut the orginal wiring off the old pump about 3" away from it and connect to the new pumps wiring harness which comes with it trying to keep the harness about the same lenght as the original,I used 2 straight blue electrical connectors to do this,on the old pumps wiring the two wires were black/red and black the black/red one is your positive and is to be connected to the red wire of the new harness and the black to the black.
(Bet your now thnking about electrical wiring floating around in a tank full of highly flamable petrol[])
You should know have something like this[]
Refit the orginal fuel pipe to the new pump and your ready to fit the assembly back in again,to do this just put the whole thing back into the tank and slide the carrier back into its mounting bracket on the base of the tank,then push the antisurge tray down to make sure it sits on the base of the tank.
Then reconnect the pipes to the cap,the pipe from the pump goes to the lefthand connector of the cap and the fuel return pipe that is connected to the tray on mine(see pics) goes to the other(plastic) one.
Refit the electrical connectors to the cap and refit the cap with its rubber seal making sure it all seated properly,then fit and tighten down the lock ring and reconnect all the pipes and connectors etc but leave the metal cover off for now[]
Now reconnect the battery.
Refit/tighten the fuel cap.
Now find a gullible person to turn the ignition on while your standing a safe distance away[]now check all the pipes for leakage and if all ok,get same gullible person to start the engine[]then recheck for leaks again,leave running for a while just to make sure then if all is ok refit the metal cover etc and your done,you can now sit down a have a nice cold beer to chill out after the stress of wondering whether your car will explode when you start it up[]
now I would just like to point out (as if it wasn't obvious)that electricity and petrol don't mix so unless your feeling very confident get someone who knows what there doing to do the job for obvious reasons[]
nickg123
Thanks for posting that Fast Guy - Certainly makes things a bit clearer!
Will give it a go this weekend anyway!
antilag
i started today on mine and finishing tomorow,at this point i feel i should say thanks to ginga for all his support whilst i undergo this modification.if anyone would like to contact ginga whilst fitting this fuel pump it comes highly recomended cos he has made coments like BANG ,and its gonna blow up wen u start the car ect and now i am $hit scared especially wen i have made up all the brackets cos it didnt cum with a sleeve :cry: :cry:
turblio
Ha! yes I remember the nervous turning of the ignition key (got my son to do it cos he likes my car!)
Frank
Mart
Antilag,
Why didn't you pump come with the brakets/sleeve?
Where did u get it from. Is there a part number for our gtir?
Davey
Mart said:
Antilag,
Don't answer that m8! it was all there when i gave it to you! :p :D
