uprated Crank bearings
uprated crank bearings
i cant find any can any help on this
ashills
do u really need uprated ones the standard ones are lead copper which i was told was one of teh best avaliable
if u really need them making up the engineering place doing my engine said they probably sort some
Nad
If u balance the whole bottom end then there will be even less load on the bearings so the standard ones wil be fine.
L8r
Nad
Si..
i wanted uprated bearings too, i spoke to every company i could find and they all said the standard nissan shell's are as good as you'll ever need.
T
tweenierob
If you do decide you want to uprate your bearings try ACL.
Hkondakci
I agree with NAD, balancing the crank and other bottom-end parts is the most important issue with an high rpm engine. Uprated bearings would not be needed.
